Hi everyone, Just went thru my garage and realized I have WAYYY too much stuff laying around. Everything is in perfect working order unless specified (Memphis amp and TC Basket).
Xtant 302a SPECIFICATIONS
Frequency Response 5 Hz to 50 kHz +/– 3 dB
Number of Channels 2
Watts per Channel @ 4½ 2 x 75
Watts per Channel @ 2½ 2 x 150
Bridged Mono @ 4½ 1 x 300
Distortion (THD)
Signal to Noise Ratio > 100 dB
Damping Factor > 200 @ 100 Hz with 4½ Load
Input Sensitivity 100 mV to 8.5 V RMS Unbalanced Source
100 mV to 17 V RMS Balanced Source
Input to Line Output Gain 0 dB +/– 20 dB, Selectable in 10 dB Steps
Line Outputs: Yes
Module Ports 2 for Amplifier and 1 for Line Outputs
Crossover CM12HP Included
Power Supply Fully Regulated, Pulse Width Modulated
Operational Voltage 11 to 15 Volts
Fusing No On-Board Fuse
Fusing Requirement 50 Amp
Size (L x W x H) 14.5 x 7.6 x 2.25”
It is used but in spectacular condition only a few scuffs on the chrome. 9/10 Cosmetics 9/10 Mechanical $130 Shipped obo
Xtant P500 SPECIFICATIONS
Type of Equalization 5 Band Parametric
Number of Channels 4
Front input is linked to 3 bands of equalization.
Rear input is linked to 2 bands of equalization.
All 5 bands are available at the rear outputs in 2 channel mode.
Frequency Response 10 Hz to 50 KHz +/– 1dB
Range of Center Frequencies per Band 20 Hz – 20 KHz
Bandwidth Adjustment Q from 1 to 10
Boost / Cut + /– 18 dB
Distortion (THD)
Balanced Line Input:s Yes
Input to Output Gain: 0 dB +/– 20 dB, 10 dB steps
On-Board Noise Gate: Yes
Power Supply: Fully Regulated, PWM
Fusing 1 Amp
Dimensions 9.9 x 9.9 x 1.7 inches
This piece right here is in mint condition. From what i read its quite an eq as well. This is the p500a version which is an upgrade from the original p500. 9/10 Cosmetically 9/10 Mechanical. Asking $130 Shipped obo
Precision Power PPI 2240
2 x 60W @ 4 ohms
2 x 120W @ 2 ohms
1 x 240W @ 4 ohms bridged
THD: 0.05%
Freq. Response: 7Hz 80kHz
S/N Ratio: 105dB
Damping Factor: >300
Max. Current Draw: 50A
Fuse: 2 x 20A
Dimensions: 8.5" x 10.1"
Also in great condition is this PPI amp. Has one scratch on the top edge you can see in pictures. Great amp 9/10 Cosmetics 9/10 Mechanical $80 Shipped obo SOLD
