Looking for a new amp in a noisy car
  • 5
Speedwagon
1987 Subaru Brat, currently setup with an Eclipse 3242 (I've had this thing forever) pushing 2 ID CTX 6.5 4 ohm door speakers.
I've noticed lately that when I have everything open, I'm getting a bit of distortion at a level when I can actually hear the speakers (windows down, tops up, back window open makes for a lot of wind noise). The 3242 has been going strong, but I think it might be on its way out. It also hisses when it is cold out in winter.
Been thinking of moving to a cheaper($100-200) class D full range 2 channel. I think I'd be hard pressed to hear a difference in this vehicle with a higher priced amp, but I've never used a class D before. These didn't exactly come from the factory as a quiet vehicle either.
Something like a Polk PA D2000.2, which is only $125 on Amazon. This also, theoretically, doubles the power to the speakers from the 3242.
I should add, I'm also looking to decrease the physical size of the amp. The 3242 takes up the whole floor under the passenger seat, and I really want something much smaller since this is such a small car.
Thoughts or suggestions?
isolate the noise(typically ground loops and more often than not are bad connections not really poor grounding placement)
try it out. the class D amps with good output filters sound fine to most people. chances are unless you are a feen won"t hear any difference.
Full range class d amps are perfectly acceptable and have a MUCH smaller footprint and are usually more efficient than the old class a/b's .For some reason, i thought i remembered hearing that caps going bad can cause a hiss too. Noise floor is usually the biggest culprit of a hiss, but if its mainly when cold, that wouldnt make too much sense.
Only happens when it's cold. Like freezing cold. And it's loud, coming from the amp itself, not the speakers.
[quote name='Papermaker85']isolate the noise(typically ground loops and more often than not are bad connections not really poor grounding placement)
try it out. the class D amps with good output filters sound fine to most people. chances are unless you are a feen won"t hear any difference.[/QUOTE]
whoa did i just read that from you LOL
@LosIsATool
Thanks for the replies. I think I'm going to give this Polk amp a shot. It's a fairly small thing, at just under 9x7x2. Less than half of what this 3242 is, and I'm only running 2 speakers anyways.
lotta guys use ppi 600.2 i have the p1k mono on sub and even jeff has the 900.4 they clean amps
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
Hi guys, I’m John. Been out of car audio for probably 15 years or so. I built a couple boxes back in the day and was definitely a bass head but...
28
Speedwagon
Speedwagon
Denver, CO
Jeffdachef
    Jun 1, 2024
    May 31, 2024
