look at the "toy" my auto mech. teacher has
up^
can anyone answer my question? do ya'll just not understand what i'm asking? or don't know the answer??? i'm tryin to avoid making a new thread... but if i get no answers then i guess i have to
The JL gain setting tutorial tells you how to ajust for a specific power output, knowing the load that will be used. There are a couple of details that need to be understood.
First, the sub(s) must be able to handle that much power in whatever enclosure they're in. (duh).
Second, if you adjust with the EQ flat then any boost, eq, or loudness added later could cause the amp to exceed what you set it for. The sub(s) must be able to handle that too.. (also duh).
The risk here is that the amp will clip when bass boost is added. That's where the scope is handy. Set everything up the way the tutorial says. Then hook up the sub and play some real music. Adjust your eq for what sounds good in terms of system overall tonal balance or whatever floats your boat. Watch the scope as you turn up the volume and make sure it doesn't clip.
subs handle power check (600wrms 1200w peak) amp pushin 700w
eq settings... i wasn't really going to be touching the bass settings at all just the eq settings above the low pass filter but i'll probably have the rock eq setting on and bass setting at 0db and go from there... currently i usually have the bass at a -db on the head unit with my components in there now will definitly do some extensive testing to see what the limits are for the amp so that i know not to go over them
Crashking
Crashking
Orlando, FL
Crashking
