Look at the Deck I Just Bought!!
hey prowler pretty sure it is fully capable just found this
"System E's+: In addition to System Q Sound Control, the KDC-MP5032 features the System E's+ crossover system for the speaker and preamp outputs. You can make the following adjustments:
* Front High Pass Filter: 40Hz, 60Hz, 80Hz, 100Hz, 120Hz, 150Hz, 180Hz, 220Hz or Thru (no filter)
* Rear High Pass Filter: 40Hz, 60Hz, 80Hz, 100Hz, 120Hz, 150Hz, 180Hz, 220Hz or Thru (no filter)
* Low Pass Filter: 50Hz, 60Hz, 80Hz, 100Hz, 120Hz or Thru (no filter)"
right ??
why do you say its not active capable it has a "3 band eq and advanced crossover system"
I'm not trying to be near as assinine as this is going to sound, but the reason I say it isn't is because it isn't.
Running active means the ability to bandpass each output and that deck you just bought, just like my 25th Anniversary XXV-01D, has HP filters for the front and rear output (but no complementary LP to go with it to create a bandpass range) and a LP filter for the sub outputs but no ability to HP it as well.
haha im guessing that will work either way im not sure i would switch over to active anyway, but for 130 bucks im down. Plus im sellin my alpine to my friend, so its all good.
I think it looks just fine for what you paid and it ought to be quite capable of fronting a nice, thorough passive system. Good luck with it! //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
right ??
No bandpass? booo
CHANGE YOUR ****ING AVATAR! //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Hell no.. that creepy taptoeing bunny chick is sexy!
JCivicHb
JCivicHb
Denver
Phrozt
