Loc or rca
Deadhead0103
I have a 2009 Ford Flex and I can’t change the head unit. I currently use a loc and it works fine but it doesn’t seem to be working as loud as I know it should be. I have a speaker wire to rca adapter and can hook it up easily. Will it make a difference. Both of my amps will work with low level inputs
  1. Not right now
If you don't already, make sure you have a good LOC like
or
Make sure all the wires are tightly joined at the connections. I think there's factory amplifier. Premium sounds. That's why. Disconnect or bypass that factory amplifier first before you plug in the other two amplifier.
If you have the manual for your car Ford Flex, look up where the factory amplifier is located. The wires going into and out of the amplifier. You won't be using this amplifier. All the speaker wires has to be redirected to the power amplifier from the radio. By passing the factory amplifier. You'll have to do your own research. A wiring adjustment or harness is used for this purpose. If you cannot find the wiring harness, then you'll have to do it yourself. So harder. Try to find this already made harness for your ford Flex. Then you'll have to connect it yourself. Follow all instructions. They give you on bypassing the factory amplifier.
Deadhead0103
Deadhead0103
Austin,Indiana
Mitchell Fosgate III
NorthFramingham
    Jun 30, 2026
