Living with alternator whine for almost a year.
ohh, maybe you can get ahold of a HU that is the same brand so you can use that harness. what vehicle is this?
A4
I guess ill give wrapping the RCA's a try so long as it cant cause no harm, righ?
i had the same issue on a pioneer HU i have since removed, i grounded head unit DIRECTLY to chassis no harnesses involved, and grounded rcas, and it git rid of all alternator wine
HU is grounded directly, im not using a harness. Im gonna be giving the RCA grounding a try.
Once you try wrapping the rcas you should try the suggestion above and remove the hu from the equation by plugging an ipod directly to amp.
If all that doesnt work ground the hu directly to the amp. I know it sounds crazy but I've done it many times when I couldnt get rid of whine in many vehicles. Sometimes this eliminated it entirely and sometimes by at least 50%.
Good luck to ya!
I think wrapping the RCA's worked! Gotta take it for a ride but i think its gone and was able to raise my amp up finally.
try to ground the rcas to the car or to the amp like he said
how do you ground the rcas to the amp? Solder a wire to the outer shield of the rca to any point on the amp? Could I ground it to the same point the amp is grounded?
try grounding the head unit directly to the battery. This solved it completely for me and it cant hurt to try
gonna be a son of a ***** to run a wire up there.
Just run a temporary wire outside of the car to the battery and see if that fixes your whine. If it does then you can go ahead and put a permanent wire in. If it doesnt work then no harm done
riotburn
riotburn
NYC
riotburn
