Big Rich
i drive a 2000 buick lesabre i have done the big 3 all other electrical like alternator and battery is stock
theres a good amount of dimming when my car is stopped at a light, ive also noticed that when my car is idling and rolling when i take my foot off the brake the RPM's drop and my car kinda stops moving a little bit to the beat of the music/bass
will adding another battery help this ? i plan on getting a stinger 5 farad capacitor (i know they do nothing but i want one anyway). and i want to add on another battery, im not sure which is a good brand or what to get heres my amp specs
the amp is currently wired at 1 ohm to a single skar 12 wired at 2ohm. so im assuming its running at the full 1600 watts
cadence daytona DCA1600
4 ohm RMS Power: 1 x 50 Watts
2 ohm RMS Power: 1 x 1000 Watts
1 Ohm RMS Power: 1 x 1600 Watts
2 Amps Bridged: 1 x 3200 Watts
Frequency Response: 10Hz - 500Hz
S/N Ratio: >100 db
Damping Factor: >500 @ 100Hz
Minimum THD:
Low Pass Crossover: 35Hz - 250Hz
Subsonic High Pass Filter: 10Hz - 50Hz
Bass Boost Equalization: 0-18db @ 45Hz
Lucite Encapsulated Large 2 and 4 Gauge Connection Terminals
Dash Board Bass Remote
Input Voltage: 200 mV - 6 Volts
Dual-Amp Bridging for Double the Power @ 2 Ohms
Master/Slave Control
Adjustable Phase Control
RCA Line-In/Line-Out Jacks
24db Crossover Roll Off
Dimensions: 13" x 9.5" x 3.5"
S/N Ratio: >100 db
Minimum THD:
