lights dimming and loss of RPM's at idle ...... need suggestions please help
Big Rich
i drive a 2000 buick lesabre i have done the big 3 all other electrical like alternator and battery is stock
theres a good amount of dimming when my car is stopped at a light, ive also noticed that when my car is idling and rolling when i take my foot off the brake the RPM's drop and my car kinda stops moving a little bit to the beat of the music/bass
will adding another battery help this ? i plan on getting a stinger 5 farad capacitor (i know they do nothing but i want one anyway). and i want to add on another battery, im not sure which is a good brand or what to get heres my amp specs
the amp is currently wired at 1 ohm to a single skar 12 wired at 2ohm. so im assuming its running at the full 1600 watts
cadence daytona DCA1600
4 ohm RMS Power: 1 x 50 Watts
2 ohm RMS Power: 1 x 1000 Watts
1 Ohm RMS Power: 1 x 1600 Watts
2 Amps Bridged: 1 x 3200 Watts
Frequency Response: 10Hz - 500Hz
S/N Ratio: >100 db
Damping Factor: >500 @ 100Hz
Minimum THD:
Low Pass Crossover: 35Hz - 250Hz
Subsonic High Pass Filter: 10Hz - 50Hz
Bass Boost Equalization: 0-18db @ 45Hz
Lucite Encapsulated Large 2 and 4 Gauge Connection Terminals
Dash Board Bass Remote
Input Voltage: 200 mV - 6 Volts
Dual-Amp Bridging for Double the Power @ 2 Ohms
Master/Slave Control
Adjustable Phase Control
RCA Line-In/Line-Out Jacks
24db Crossover Roll Off
Dimensions: 13" x 9.5" x 3.5"
The sub hits very hard and neither the amp or sub cone get warm at all. I'm not sure if it's the amp honestly. I just thought that since it was 1600 watts that it pulled a lot of power from the battery.
This is my first install so I just don't know where to start looking. The last thing I want to do is screw up the car
Your amp consumes about the same power that your factory alternator will produce at peak. Your vehicle will pull most of what your alternator can produce in it's normal operating range, generally up to 80a. That's not leaving much to power your system.
Then factor in the alternator is only putting out about 50-60a at idle and you will not have nearly enough amperage available to maintain your batteries.
For your system to function properly with that amp I would recommend that you install one good battery like an XS Power under the hood, use a high output alternator with good low-speed charging and wire everything with quality cable.
CCA cable is OK when used properly.
Avoid cheap batteries.
Avoid cheap alternators that claim big power, they don't generally perform at low engine speeds.
im going to try lowering my gains a bit in case that could be part of it. after that im going to just try a battery than after that il go with switching out the alternator. what is a good reliable one ??
what are the minimum amps the battery should be ???
had the same problem with my park avenue a few years back threw a kinetic 1800 and ran great i was running a saz-1000d at the time. I still have the same battery in another vehicle but no stereo anymore //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Big Rich
Big Rich
Brooklyn NY
dot8905
