Light weight SPL setup
jeffs42885
Experienced Noob
1,130
DFW
Hi all,
As you can tell by my sig, I used to have a pretty good system in my Grand prix. I beleive I did a best of 141.2 on a termlab. I currently have two cars.
1) Daily driver- 2011 Scion TC - 1 12'' Type-R, ZX750.1, Audioenhancers box, best of 138.6 on the term.
2) G8 - did 135ish with a 12'' L7 and the same amp.
The g8 is my weekend car, I have some performance/visual mods done to it, I dont drive it in the winter, I like to take it to the drag strip, and most importantly, shows.
As long as I have been doing audio I have used a single 12'' setup. Here is what I want to accomplish.
The G8 is lacking in the audio area. I have nothing as of now. I would like to do a nice trunk setup, something squared off, that sounds good, and gets loud. I would like to do this with as little sub as possible, 1 12, 2 10''s, etc. I have the following dimensions for a box:
47 wide, 16'' high 16'' deep. I am also using the factory headunit and a cheapo line out converter. Amp, I will probably use a sundown audio, or a kicker ZX..something in the 1500WRMS range. What does everyone think. I would like to be able to do a 140 in this car....without adding too much weight. Of course, the box is removable..
What is lightweight to you?
Are you trying to get loud on music or tones?
Are you trying to compete with this?
I'd like to be loud on both. Like I said, If I had a setup that can do a 140, and still sound great, thats good enough for me. Heavy..weight..hmm..Maybe like..less then 75lb..
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
601
I am not well versed in box design, so I do not know outcomes based on over/under sizing. The one thing I do know is that too big of a port will...
598
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
jeffs42885
Experienced Noob
jeffs42885
DFW
jeffs42885
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
