let's try this one more time
wafsman
okay, so i have this bad problem of making things way more difficult than they need to be. so i think i have come up with the best solution. i won't be cutting up the truck, or making big *** contraptions in the bed. i will give up my back seat and put my system inside, i think this will be the easiest route. i had a box designed for me, so i just implemented that into my own design. what do you all think, am i finally getting it?
the completed view, this will be behind the seats.
a view with the front of the sub box off, so you can see the inside of the box.
yeah, all the rods will be connected. they will have screws connecting them to the outer wall and will all be glued to a 1" square block in the middle
the gray boxes are supposed to be the fuse holders
actually came up with a new design for the bracing. had some people tell me that the bracing before might cause some port noise. the new design is two 1x2's running down the side and a 1x1 across the top that sits inside the 1x2's for extra support. i think this will be strong and shouldn't cause any noise. what do y'all think?
wafsman
wafsman
ohio
wafsman
