less response
theycallmecrash
hey guys. i recently built a box to hold my amp, and two subs underneith a custom seat in my truck. since i dont have much money im runnin 2 12" xplodes. which i knwo you all hate. but hey. they work. i had a box from bestbuy when i first started into it all and it sounded great. it was a sealed box divided. after installing my box though i noticed that at higher volumes teh bass basically hits a wall and stops. distortion starts alot earlier and it all just doesnt sound as good. included are pics of the new box. dimentions are 55x14x7tall. estimate teh middle section. the second picture is the layout inside the box with the top off drawn with paint.
welcome to the site, and what did you do, just build a boz and put a port in. cuz you cant do that, you have to tune it properly to get what you want out of it
x2 however it does look like u have some carpentry skills. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i did a little reading and it all somewhat makes sense. but if the box isnt big enough, wouldnt a larger hole trick it into thinking its in a bigger box because of pressure differences?
well. i cut out the ports to the full size of the baffles. and discovered my amp was set to 150hz for my subs. turned it down a bit. not sure which one of the two changes i did made the difference but the sound is back to par. check my gallery to see the changes. i thought the ports would be to big. but hey. it works. let me know what you think.
theycallmecrash
theycallmecrash
colorado
theycallmecrash
Mike Mccabe
