Less RCAs
86monte
Im trying to figure out everything i need (as far as wiring goes) to install my system right now and i am looking to run as few wires as possible. My main concern is my RCAs. I will be running atleast 3 maybe 4 amps one or 2 for speakers and definetly 2 for subs. Do I have to run a set of RCAs for every amp?
What amps are you using? I have an 85 Monte and I might run 4 amps. If your sub amps are strappable, there should be no issue there. If your highs amps have pass throughs, use those.
See the third set......
What I haven't figured out yet was if using a 4 channel amp through those do all 4 channels work. I gave that amp as an example because I'm gonna use one of those.
86monte
86monte
Knoxville, TN
fasfocus00
AJ (ACE)
    Jun 28, 2026
