less ohms = more heat?
sdime808
HI
I have two 2ohm DVC IDQ's and a Soundstream ref 500s which is 2 channels. I heard that this amp can really heat up so I want to configure it so that it runs as cool as possible. My options are to run it at 1 ohm on each channel or 2ohms bridged. Is it safe to assume that running it at 1 ohm on each channel will make the amp hotter than 2 ohms bridged? will there be any other effect?
resistance effects heat - indirectly. As you lower the impedance the amp will be able to generate more power - which is where the heat comes from.
It's really not an issue with your question anyway, because to the amp - 1 ohm stereo is the same as 2 ohms mono. It will make the same amt of power.
I asked that question because I wired up my subs at 1 ohm stereo and put it in my box and everything. I haven't tested it yet but I just realized that I could have wired it at 2 ohms bridged with the same power. Now I'm having second thoughts about leaving it at 1 ohm, and if it will function with less heat at 2 ohms bridged then I guess I'll take them back out. But that would mean desoldering and resoldering my connections. I only want to do that if there will be a significant difference in heat produced. Thanks for you replies though!
sdime808
sdime808
HI
sdime808
