LED's and AMP
there blue.....then wire them in a series meaning all negs and all together then positive to power and neg to ground....then i can wire them right up with my power and ground right @ my amp?
ok sounds easy enough....so could ground be where the ground for my amp goes into the amp...and could 12V be piggy backing the remote wire thats the for the headunit that goes into the amp?
i just did the same thing, except I wired 4 in series to give me the 12v. If you wire them straight off the amps positive and negative, then they will always be on. I first hooked them up off the remote wire, but it wasn't suplying enough juice, so I bought a relay, and have the 12v going tot he relay coming off the amp. This way, the leds come on when the HU is powered up.
dvrmstrng
dvrmstrng
DE
dvrmstrng
