LED question
SPLguy420
Pimp
Anyone know how to wire these bastards?
where does wire go? i dont know whats - +
thanks!
ahh, those are fun //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif let me look at mine real quick...
You use the opposite diagonal wires as the things to wire to...just test them with a battery to see which one is pos/neg. You can tell the difference between the sides because when looking under it, one side looks like its connected to the led, and the other looks like its not. I forget which is neg/pos. Play with it.
make shure there wired with resistors or they will blow.
im going to wire it from my 12 volt so i bought
6 Red 10000mcd 2 volts, and 4 Blue 7000mcd 3 volts, im not sure which one ima use, ill prolly see which color i like better. but i dont need resistors if i do this, right?
SPLguy420
Pimp
SPLguy420
michigan
req
