Insomniac119
i can't sleep
You still need a resistor though, no LED won't fry without one. Just place it anywere in the series.
Not nessecarily. It the LEDs are only pulling 3V and have a max forward voltage of 3.5V, there you don't need one.You still need a resistor though, no LED won't fry without one. Just place it anywere in the series.
thats absolutly not true.You still need a resistor though, no LED won't fry without one. Just place it anywere in the series.
You're absolutly correct! Although you can send me 20 bucks paypal for agreeing with you if ya'd like //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifthats absolutly not true.
the max forward voltage is 14.4v, if you wire the LED's in series, the whole array will use 14v. the LED's are usually 3.2v each, so if four of them are wired in series, each LED will get around 3.6 volts - wich is fine, considering that they arent constantly used 24\7. if you wanted to be on the safe side, wire up 5 led's for the array.
all the resistor does, is bump the 12v source down to 3.2v - while instead, you can just wire them all on one wire and not have to deal with the resistor.
resistors arent needed for every LED install my good sir. learn your electronics a little bit more //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if you are still doubting me, ill make one up, hook it to my battery terminal with no resistor for 24hours and you can tell me if they fry... hows that? ill even send you $20 paypal if they do.
Well then good, I learned something. After reading that explonation, it makes sense to me now. I've never wired up multiple led's before, just one at a time, and so I didn't think that it could work that way.thats absolutly not true.
lol.
heres what ya do.
when the car is on, they will get 3.5v each - the array should only pull like 80ma of current, so dont worry about it, but make sure your wire can supply that. if you wanna put them in your dome light, you can just hook directly to the +\- of that bulb jack. if you wanna do accent lighting, you can hook into the fusebox in the dash on a switched wire (key on = power, key off = no power) and you can put some kind of switch (potentimeter? sp? lol ) on the negative lead to power them on or off depending on your mood.
hope that clears it up. anything more than 4v for a few seconds could possibly kill them. that might be your problem.
you shouldnt need any resistors if you just wire them how i have shown above by the way.
Your gonna burn up those LEDs if you wire them up like that... the apmerage on a car battery alone could fry themput a 270 ohm resistor in the circuit and you'll be fine
like what, $0.89 at radio shack?
Yes, in my experience, when an LED says 3v max it MEANS 3v max (imagine that //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif ) I went through the effort of soldering 2 long strings of them but never figured 12v vs 14.4 would be that big of deal when its only like .5 volt difference per LED, I was wrong, within seconds of the car on, one by one they bit the dust //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Thats what we call learning the hard way...technically, if you just set up the LED's to run at the max voltage for the car - ie 14.4 (like i used in my picture) you arent going to be frying anything, because it will rarely always be 14.4, and if it drops, thats even better for them.
so why go thru all the trouble. mine are working just fine.
and luxeon stars are all good with a bag of chips, but you have to heatskink them, and they put out an awful lot of light for 'accent lighting' //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
