Last QUICK amp turn-on question. Help!
jriley3
OK, so i'm trying to connect my small blue amp turn-on wire to the headunit area. the problem is the blue amp wire coming from the cars factory wires is cut too short and would be a pain to get to, but my headunit has a blue and white amp wire coming out of it not connected to anything. Can i connect my amps wire to the head unit directly and then my headunit will tell my amp when to turn on?
on the head units wire diagram, it says to connect that blue one to the system control terminal of the power amp or auto-antenna relay control terminal. so can i hook the amps turn-on to that?
jriley3
jriley3
Albuquerque, NM
dabringa
Mike Mccabe
