lanzar
how do i go about that? i usually make my cousin intstall all my audio equipment cause he is an installer for sound wherehouse but i have a feeling ill be wiring this amp so how do i run it at 6 ohms? should that be just how i set the adjustments?
like this - the pic shows 4 ohm subs, but since yours are three the final impedence will be 6 ohms.
i have two 10's i cant bridge my amp can i?
Sure you can - just like the pic ^ shows.
so how many watts would the amp be running paralelle
This isn't a parallel connection - it's series.
The 500.2 does 900+ at 4 ohms, 500 at 8 ohms, so roughly 750 at 6 ohms, but since it's so under-rated I'd expect a good 800-900w, that's 400-450 per speaker.
Or, if you'd prefer, you can just wire a sub per channel, like it's a regular pair of speakers. Power will be the same.
the opti should handle a 2ohm load... and most likely the 1.5 ohm load that your subs would have when wired bridged/parallel. It is possible that the amp may overheat with that set-up too...
You could try both... I would lean towards 1 sub on each channel.
lanzardriver
lanzardriver
salt lake
lanzardriver
