Lanzar Vibe 248 ???
audiobahnuser18
alright i need an amp for my 2 12's they are audiobahn's awc12t's 500 rms dual 4 ohm voice coil 500 watts a piece do you think this amp would be good? its a good price i think
Lanzar Vibe 248
2 x 300 Watts RMS at 4 Ohms
2 x 600 Watts Max at 4 Ohms
1 x 1200 Watts Max at 4 Ohms Bridged
2 x 500 Watts at 2 Ohms
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohms Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Line Outs For Left & Right Channels.
Power & Protection LED Indicators
Advanced Protection Circuitry
Soft Turn On/Off
Remote Control Bass Booster
Frequency Response: 15 Hz - 35 kHz
S/N ratio: 90dB
Dimensions: 11.5"W x 2.3"H
It's not a bad buy - unfortunately it's WAY over-rated.
I can't tell you the exact power of that amp, but I can tell you the 268 was tested at 923w bridged, the 258 is rumored to be around 700, and I know the 238 isn't more than 300. So the 258 has to be in the 500-600w range.
For ~$130 it's not a bad buy at all, and 250-300w per sub would be plenty of power to get them moving pretty well, but you could probably do better for not a whole lot more money.
FWIW - there's a pretty steady flow of Vibe 1200D and 1800D refurb's on ebay, there's even a couple Heritage 2600D's - all for ~$140-160. They all use basically the same board and all will do 1000w+ at 1 ohm which would be ideal for a pair of 500w dvc 4's. The $111 1200D's are probably the best deal out there for cheap sub power.
audiobahnuser18
audiobahnuser18
Mi
Worlddre
