lanzar optidrive 2500d amp questions
if its the black 2500, then thats the original model
and they are AWESOME (ive owned two) should have kept em
do power EASY, dat cool, but the harder you drive them , they can get hot
if you find one and dont want it, let me know Ill take it
while i was reading the manual on the specs, it was 1000w bridge at 4 ohm @ 12v( thd 0.01%), but its 2020w @ 14.4v, i know most manuf. company test and rate their amps with 14.4, so for those that have used this amp, didn't seem that high of wattage at 14.4 while the car running with dual batteries.
yeah that means 2x500. it prob wasnt pushing that power. lanzars ratings dont make any sense. in their lowest ohm load, they usually give a max rating. also, going by amp guts, they seem to have the once in a lifetime results on some of their amps they show. id have to see the test to see that thing do over 2000 watts.
You clearly have NO knowledge of Lanzar's amps of that era.
2000 does indeed seem a bit optimistic, but Lanzar's current offerings have NOTHING in common with the '03 and prior models. Not the designer, not the builder, not even the continent.
Those were extremely under-rated amps, and will often still sell for 200-300. I'd be shocked if that amp doesn't do 1200w comfortably, and not surprised if it's 1500 or better.
I think you mean prior to 1997, that is right about when Pyramid (Sounds Around) bought them.
saltyreefguy
saltyreefguy
palmdale, ca
bigblank69
Mike Mccabe
