Would anyone be interested in some refurbed Lanzar OPTI1000D's? I have 6 that were ran at .5 ohms for close to a year which caused them to fail. I'm thinking about sending them into Db-r.com and getting fixed. All of them are in good to decent condition. I'll have pics probably tomorrow with my name and date but if there are serious takers I would like a small down payment or do a partial trade so I know you mean business. These amps are beasts and put out more than rated power with ease. Here are some specs:
350 Watts RMS Power @ 4 Ohms
650 Watts RMS Power @ 2 Ohms
900 Watts RMS Power @ 1.3 Ohms
1000 Watts Max Power @ 1.3 Ohms
Mono Block Subwoofer Amplifier
1 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload Short Protection
Remote Bass Control
Soft Turn On/Off
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Variable Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to +18dB
Phase Shift Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 3
Dimensions: 10.08'' (W) x 2.12'' (H) x 12.59'' (L)
1 Ohm Stable
MOSFET Power Supply
Remote Bass Control
Soft Turn On/Off
S/N Ratio: 90dB
