Sold Lanzar Opti1000D
Mattd0344
Would anyone be interested in some refurbed Lanzar OPTI1000D's? I have 6 that were ran at .5 ohms for close to a year which caused them to fail. I'm thinking about sending them into Db-r.com and getting fixed. All of them are in good to decent condition. I'll have pics probably tomorrow with my name and date but if there are serious takers I would like a small down payment or do a partial trade so I know you mean business. These amps are beasts and put out more than rated power with ease. Here are some specs:
350 Watts RMS Power @ 4 Ohms
650 Watts RMS Power @ 2 Ohms
900 Watts RMS Power @ 1.3 Ohms
1000 Watts Max Power @ 1.3 Ohms
Mono Block Subwoofer Amplifier
1 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload Short Protection
Remote Bass Control
Soft Turn On/Off
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Variable Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to +18dB
Phase Shift Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 3
Dimensions: 10.08'' (W) x 2.12'' (H) x 12.59'' (L)
thanks man. can't find them nearly that cheap anymore. c'mon ppl with 1500D's! I'll trade a couple of these plus cash. easy to get them fixed for pretty cheap by Chris at dB-r.com. I just dont have the time...going to college in a few days.
Yes, Zed made. Any Lanzar Opti with a number then a . then the number of channels is Zed made.
Example, Opti 1000.1D is Zed. Opti 500.2 is Zed. Opti 400x4 is NOT Zed.
Also, curious as to what happened inside these amps. I had one that the smaller toroid came completely off the board pretty much. Chris at dB-r quoted me about $100 to get it fixed since they're very heavily built amps.
Mattd0344
Mattd0344
Colorado
xhilr8n
