L7S not hitting hard
It looks like 1500rms total which is 750rms each sub. Description says it’s wired to 2 ohm. If you changed the wiring and made it 8 ohm that’d make a difference.
I think the goal is to be between 20% over or under on wattage supplied by the amp.
If that jd puts out 1000 at 2 ohm you’re really 33% under par at 2 ohm.
May want to double check wiring and double check gain setting.
I set the gains with an oscilloscope the wiring seems fine I think it’s underpowered don’t get me wrong it hits still but I thought it would be harder I just received a new amp the kicker cxa 1800 that should work.
Carlos1son
CarAudio.com Regular
Carlos1son
old bridge NJ
deez283
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
