L7 ported or sealed?
klepto
Perveyor of Filth
what are you personal opinions on the best way to get my L7 runnin well. It will be running of a Ca-1200 amp at 2ohms, 900watts rms. right now i am leaning towards a 3 cubic foot ported box but still not sure. thanks
Originally posted by klepto what are you personal opinions on the best way to get my L7 runnin well. It will be running of a Ca-1200 amp at 2ohms, 900watts rms. right now i am leaning towards a 3 cubic foot ported box but still not sure. thanks
i would port it....
Wait a sec that amp is only stable to 4ohms bridged and thats what that amp puts out bridged. What type subs do you have, dvc 4ohm or dvc 2ohm. If it is dual 2ohm then wire the vc's in series and bridge the amp. If it is dual 4ohm then wire each coil to its own channel and it will get 600 rms.
Originally posted by 80_Cutlass_mn Wait a sec that amp is only stable to 4ohms bridged and thats what that amp puts out bridged. What type subs do you have, dvc 4ohm or dvc 2ohm. If it is dual 2ohm then wire the vc's in series and bridge the amp. If it is dual 4ohm then wire each coil to its own channel and it will get 600 rms.
isnt the l7 svc 3ohm?! //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Nope its either DVC 2ohm or DVC 4ohm. I'm not too sure if it comes in a SVC version or not.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Originally posted by 80_Cutlass_mn Nope its either DVC 2ohm or DVC 4ohm. I'm not too sure if it comes in a SVC version or not.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
oops, my bad. i saw l7 and thought w7 //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
you're right, they're either 2ohm dvc or 4ohm dvc.
Yup and for the Profile CL1200 and the CA1200 then you would need the DVC 2ohm so that you could wire the coils in series and then bridge the amp and get 900rms. Allthough that would prolly be a lil too much for the even the L7's so id keep the gains turned down. But if you wanted a sure enough loud burp and had a large ported box. Crank them gains up a lil and burp them suckers and your bound to be deaf;) //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i am running mine 2.0 cubic feet sealed...iwas a bit skeptical at first...cuz i had it in a ported 2.5 before...didnt give me what i wanted
now it sounds really clean and goes low and a bit loud
loud enough to trip off many alarms ( i didnt do it on purpose...i was jus testing)
oh its runnin off a jbl 1200.1 at 4 ohm
good, ill be sending my L7 600watts@4ohms in a 1.5^ft sealed box..(aint a lotta room in the back of a jeep). gettin it all finished up and runnin tomorow =)
Originally posted by klepto good, ill be sending my L7 600watts@4ohms in a 1.5^ft sealed box..(aint a lotta room in the back of a jeep). gettin it all finished up and runnin tomorow =)
lemme know how it sounds
although i think you should go 2.0 cubic feet
stuff it 50% with polyfill...also make sure the sub is broken in properly
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
For what it’s worth… I picked up a mti stage 4 or 5 for around 900.00. Loaded with jl tw3 it’s was 1995.00. Which is a good 1k off what I would...
Assuming the taget curve is the same they will sound very similar. 2nd and 3rd order harmonics might be different but are offer hard to even hear...
😂😂 I actually have a CNC at my shop (I make drone parts for a living). It’s just that I got intimidated by all the tuning (equipment I don’t...
18
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
klepto
Perveyor of Filth
klepto
San Jose, CA
pioneer
    May 24, 2024
    May 23, 2024
