L shaped ports
If you need a 42" port, your port should measure a total of 40" down the middle. Using a side of the box for the port will cause the port to continue 1/2 of the width after the end of the port.
the tutorial says to add 1/2 of the width of your port on to the end of the vent length :/
So measure down the middle of your port until you get 40" then that's it.
Is the port calculator you are using figuring for a slot port? Or a normal port?
http://www.carstereo.com/help2/Articles.cfm?id=31
This one has the option to pick a slot port and will automaticaly deduct the port end correction. Notice when slot port is selected it will deduct half of the port's width from the length. That is for the port end correction.
And you build custom enclosures???
yea, i didn't say i design em //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif am learning though... my skill is with wood, not math
So how skilled are you with wood? If I give you my wood what could you do with it? It's rather large and thick, you may have a hard time with it. Are your wood mastering skills expensive? I have a local wood expert who knows how to work with it;)
well i'm actually quite cheap //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you dirty, dirty man... lol
a cheap man who is good with wood... where do i sign up???
MAN? I thought he was a goat //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Never mind //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
psych0ticnemes1
Psych0tic Customs
psych0ticnemes1
Behind You
psych0ticnemes1
