L.E.D. Wiring Diagrams
Trancer
With the many questions about how to wire LED's, here is a great set of diagrams on how to wire LED's. I think this should be stickied as often the quesions are asked.
Notice the load resistor that IS needed. For LED/load resistor information check out THIS SITE. Also notice that the Anode on the LED is connected to positive. The Anode is the LONGER lead.
NOTE: If using a light up switch connect the 3rd connection on the switch to ground.
Similar LED Wiring Diagram
Here's a similar LED wiring diagram showing 4 seperate LED's (NOT connected). Notice the load resistor that IS needed for each LED. For LED/load resistor information check out THIS SITE. Also notice that the Anode on the LED is connected to positive. The Anode is the LONGER lead. NOTE: If using a light up switch connect the 3rd connection on the switch to ground.
Multiple LED's Wiring Diagram
Notice that NO load resistor is needed. For LED/load resistor information check out THIS SITE. Also notice the Anode and Cathode connections. The Anode is the LONGER lead. The LEDs MUST be connected in series, NOT in parallel.
12 LED's Wiring Diagram
Images courtesy of http://www.oznium.com
What size resistor would you need exactly? And how many LED's would you need in series before you don't need a resistor? 4 like in the picture? Reason I'm asking is because i have no idea the resistance of an LED light.
Trancer
Trancer
Allen, Texas
Trancer
