Kx1200.1 and two L5 12's wired to 1ohm
cstabler
Diamond
I have bought two L5 12's 4ohm model and a KX1200.1 and have made a custom sealed box.. now... I'm having second thoughts.. is this set-up alright? I know the KX1200.1 put out more than just 1200 watts RMS and each L5 is rated for 600 watts RMS.
I have a custom built 200 amp alternator also..
Plan on doing the "big 3" while im installing the above.
dose anybody see anything wrong with what i'm doing?
Edit.. Also I'm Using 0/1 guage wire for all power transfer.
and 12 guage for the speaker wire.
Are those L5's SVC 4ohm or DVC?, if SVC I dont see how you can get the 1ohm load.
Otherwise, thumbs up. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I was just wondering because of the RMS power being higher than 600 to each L5 or more specificly more than 300 to each coil...
a side question.. how should I wire the subs? with a wire to each terminal/post so 4 wires to each +/- socket on the amp? or two wires to each sub with the single wire connecting both +/- posts on the subs.
I realise both are an 1ohm load and both are wired in parallel.
Another question.. should I spec out each speaker wire to be the same exact length down the the milimeter so not to create more resistance than the other?
I was just wondering because of the RMS power being higher than 600 to each L5 or more specificly more than 300 to each coil...*The'll take it no prob.
*See here-
http://www.caraudio.com/vb/showthread.php?t=31984
*Just try to keep them close to the same distance, down to the last millimeter is not nessesary.
cstabler
Diamond
cstabler
ohio
stones
