KRYPTO's Krytonite
Here is the box I use to have with the subs running of an Insignia NS-A1200 lol
But I have nitous now and couldn't fit it back in //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Did the math and it is net 4.05cuft tuned to 36Hz
never got it, and you got it from Mach 1? The one in Little Canada? I got metered there and that shop is sketchy.
Yep F*ck 1 built it. I wasn't please. I'll sent pm again
i was just up the goldenvalley Mach 1 yesterday.
small and seems shady to me, and nothing for a showroom floor.
i was just picking up some wire to hook a amp up. they didnt have any 4 gauge, so i bought a kit from them.
im no expert at all for car audio, so they might be good.
if anyone local is willing to build a box, i need a stealth box to fit under my rear seats that will take 2x 12 incher. for a Hummer H2.
just PM me
Got it all installed , I'm not very impressed with the sounds //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif even with 4x the power it just doesn't compare to my ported box.
Anyways here are some pics. I will be redoing the wire when my fuses show up.
First time and it was cake walk
I hope the lines go away....
Bottle warmer all wired up
Everything that needs to go in hatch
Quickly made up a battery hold down and mounted battery
Nitrous tank brackets and one sub in
Just missing amp and some power wire
Started on power connections
Ground
Power and power block
Amp mounted and power wires all set
Yay all finished, now time to be let down //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
when you want more bass, 1 ohm will do those arrrhhs justice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif plus with that battery in the trunk you'll be fine. imp rise will put you closer to 2 ohms anyways.
glad you like the amp. its a beast indeed.
The intelli Q is kinda finicky, but I think I have it figured out.
I have them at 4ohm with gain maybe 5/8th cant go much higher. I'm going to tweak the deck and amp some more today and see if I can get it to hit hard like my ported box.
My fuse holders should be here tomorrow, then all I need is a ported box from someone.......... //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
I'm already planning on going, maybe meet up by you and cruise together? Just need to figure out how to tune this crap lol. I'm going to have bassman3 build the box, he was very helpful in figuring out what and how to do it. Plus he's the only one that I didnt scare away lol
KRYPTO
KRYPTO
MN
KRYPTO
