KOLOSSUS vs. KLM WIRE
I've got KLM I'm using for my big3. Kolossus is pure copper, where as KLM is copper clad aluminum.
I doubt there's much difference between them as far as performance though. I'm not sure which is more flexible either... probably the KLM.
I'd go with KLM. Save yourself some money.
You have no idea!. I recently drew up a Schematic for my up and comming system to get a list of wire, fuse holders, disto blocks, ect. ect. the list came to $1141.60! Some of my earlier sound systems didn't even cost that much.
Here is the list:
KOL1/0BL 75FT. Kolossus Kable 1/0 Blue Power Wire $243.75
KOL1/0S 75FT. Kolossus Kable 1/0 Silver Power Wire $243.75
KOL4BL 25FT. Kolossus Kable 4 Gauge Blue Power Wire $33.75
KOL4S 25FT. Kolossus Kable 4 Gauge Silver Power Wire $33.75
KOL8BL 25FT. Kolossus Kable 8 Gauge Blue Power Wire $16.25
KOL8S 25FT. Kolossus Kable 8 Gauge Silver Power Wire $16.25
KAR124SS 130FT. Karma SS 12 Gauge Bi-Wire Speaker Wire $182.00
KAR08SS 30FT. Karma SS 8 Gauge Speaker Wire $49.50
KBT-30N 1: KonFused Negative Battery Terminal $18.99
KBT-30P 1: KonFused Positive Battery Terminal $18.99
RT1/0516BL 16: Gold Plated 1/0 Ring Terminal – Blue $28.00
RT1/0516BK 21: Gold Plated 1/0 Ring Terminal – Black $36.75
FD1263BK 10: Female Disconnect 12AWG Black $5.00
FD1263R 10: Female Disconnect 12AWG Red $5.00
BC-1448 2: BC-1448 Kompression Distribution Block $11.98
KND-23 4: KonFUSED Ground Distribution System $69.96
FH-20 1: In-Line Waterproof ANL Fuse Holder w/ 150A Fuse $19.99
FH-44 1: In-Line Waterproof Mini-ANL Fuse Holder w/ 30A Fuse $7.99
KNF-23 2: KonFUSED 3-Way Distribution System w/: $39.98
40A Fuse
30A Fuse
60A Fuse
120A Fuse
120A Fuse
120A Fuse
SHIPPING $19.99
TOTAL $1141.60
I'm not going with that many amps/speakers, but i'll probably spend the same on all the installation parts. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
And I am going with all Kolossus.
for resistance klm is better for the money. as far as quality kollosus is much better. i dont use klm for the main reason that in the cold it gets horribly stiff.
OK but that would only be a concern when installing right?
What are you running with?
Kolossus is pretty much 2/0. I ALWAYS have trouble getting it into 1/0 fittings. I'd still try to run it amongst the batteries.
IF I needed that size I would, but I have all my runs referenced to a wire chart guide that I should only see a .5V drop because of my wiring.
2fnloud
Know Y U belive what U do
2fnloud
Ithaca, Michigan
2fnloud
NorthFramingham
    Jun 30, 2026
