Kole Audio QX1-2400D
Spooney
Amp is used but in fairly decent condition. It has some pretty good size scratches on the underside edges of the heatsink but once it is mounted down you would most likely never see them.I have included close up pics of the worst of the scratching below. Other than that the amp is in pretty good shape. Mounting feet are not original. I bolted these heavy duty steel mounting feet to the bottom plate of the amp. They are stronger than original and don't look too bad IMO. Power inputs are 4 gauge and speaker outputs handle 8 gauge I believe. Amp is rated for 1800 rms into one ohm however it falls a bit short of that . It will do a solid 1400-1500 rms at one ohm. Same design part for part as a powerbass asa 1500.1dx just layed out a bit differently on the board. I have the owners manual for this as well.
130 Shipped anywhere in the lower 48.
Included in price. I usually use Fedex or USPS but if it has to be UPS I will do that to.
Thanks bro. Really is decent power for the money and you are 100% correct about the board being the same as some of the older planet audio and sounstream amps. Forgot to mention that myself.
Spooney
Spooney
Charlotte,MI,USA
Spooney
