knukonceptz wiring kit enough for nissan titan?
There should be enough wire length-wise, but it really depends on where you run the wire and how many obstacles you have to wind around to get to the amp. But most likely, you'll be fine with ~18 feet. 4Ga should be ok for the most part - if it's the only amp you're going to be installing and you're sure you're NEVER going to upgrade/add more, it's fine. If you plan on adding more amps or going bigger, I'd go with 1/0 now to save the hassle of changing over later.
youll have to cut it to put in the in-line fuse. Itll still be enough though. I have an 06 titan an my run was a lil over 16'. I also went down the frame an entered the cabin through a hole under the passenger seat. Was a PITA but better than going through the firewall
Just an fyi, that amp is fused for 150 amps of current and the Knu KLMX wire is only rated for 100 amps. You'd have to get the Fleks wire.
x2. I didn't know the amp had such a large fuse rating - you'll have to make sure the 4ga you get is at least TRUE 4ga - oversized 4ga would be even better. Make sure it's OFC as well, not CCA (so the fleks, not the KLMX as stated).
pd298
pd298
oklahoma
pd298
