Sold KnuKonceptz 1/0 Gauge 2 Way Digital Mini ANL Fuse Block
"Two input ports, which by changing the Kompression Fitting, can accept 4 Gauge or 1/0 Gauge Cable. The output side can be adjusted to accept 4 Gauge or 8 Gauge cables. Please see our reference chart link below to see what fittings are included with this model. Using the Mini-ANL Style Fuse, the KNF-22D can maintain loads up to 150A per circuit.
The Digital Display is illuminated by Blue LED's and requires a ground wire to be connected to the base mounting screw on the output side of the block
Included with the KNF-22D are 6 Kompression Fittings to allow the end user to customize the block to fit their application. Also included, your choice of two (2) Mini-ANL fuses! The KNF-22D is finished in black chrome and includes the smoke acrylic cover "
http://www.knukonceptz.com/assets/Tech/specdfb.htm
Under KNF 12 for the combonations u can do with this block
Just the fittings it comes with out of the box...its basically brand new, just out of the box....Never hooked up/mounted or anything of that nature.
Team MAF
Team MAF
IN
Team MAF
