Kinetik power whole car?
36 ah seems pretty small for a starting battery, and I can't find any mention of Kinetic's CA/CCA.
There are people running 2x the power with minimal electrical system mods.
If your alt is 100A or more and the HC800 will start the engine it SHOULD be adequate as a main battery, but I would talk to Kinetic first.
I talked to Kinetik and they said the lowest amp battery to use while powering a whole care is the HC1400. If I run a dual battery setup and wire it parallel (+ to+, - to -) and fuse the positive and then do the big 3 on the Kinetik would I be good?
bradfordpoole
bradfordpoole
Statesboro, GA
audiolife
