Kinetik or Yellow Top
i have the same dillema. with my stereo even partly up when the bass hits the needle falls. i have big 3 0/1, 0/1 power/ground, new 130a alt. i'm thinking battery is the problem. looking to get 2 g34's. what do you guys think?
you need a batteries and and alt because your "needle falls"?
did you even get a multi meter on there to see how much voltage your dropping?
just cause your "needle falls" doesnt mean you need an HO alt and 10 batteries. for all you know you could be dropping from 14v to 13.2 volts....which aint shit.
Why would you say that I here Kinetik is the best only that they have a slow discharge rate why would power master be better?
and thats the problem....
"i hear xxxx"
"well i heard xxx"
"so i hear xxx"
why not stop going by what you hear, and go by whats proven? the funny thing is the stuff you hear from those people...are just what they heard from someone else anyway...
and another thing...dont compare your 1kw setup to other peoples.
some people said they could run a kx2500.1 off a stock electrical....you cant.
i have a kx2500, 200A alt, and a upgraded battery....voltage drops
lakota has one and a 200A alt, an hc1800, an hc 2400.....voltage drops
sure you can run it off a stock system if your gains are conservative as hell. but why claim to be running a kx2500 on a stock electrical when your gains are only set to give out 1500 watts?
what size alt you have btw?
What's the difference in price between a yellowtop and a 2400 for you guys? I can get a yellowtop for under 170. a 2400 is a lot more. My I'm running a Red top up front and a Kinetik hc800 in the back .
stock 130a
probably the same exact alt thats in my friends explorer.
you have a v8 right?
the dash configuration is the same as well i would bet. my friends explorer does the same exact thing. like i said i would get a multi meter on there and play a bass song that has consistent basslines so the dmm can catch up, and find out what your dropping to.
skrilla22
skrilla22
Tacoma, Washington
jco1385
