Kinetik, Optima YT, or other?
Wolverine19D
So currently I am running a cheapo regular battery and have a HC600 kinetik in parallel. I am running 1500 RMS at 1 ohm and my alternator can't keep up. So I know eventually I will need a bigger alternator. But I am thinking of replacing my starting battery for now as a temporary help and then do the Big 3.
So since I already have the HC600 in the back, would it be wise to get say a HC1800 , or should I get a Optima YT for my starting battery? On the website it didn't recommend mixing up the batteries. So would it even be possible to use a Optima YT with my kinetik? Sorry I am confused on what to get and could use some advice. Thanks guys!
Thanks spanky... so if I get a Optima YT can I use my kinetik 600? Anyone else have any opinion on what battery to order? Thanks
Whoa there noobster...that's SPANKY69XXX to you...not "spanky"...I've worked too hard to earn that moniker. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
XS power is the way to go man, their batteries are much stronger than than kenetiks and usually smaller...
The S3400 batt is when used as a primary batt can handle a 2500 watt system, along with having a steel reinforced case which is made for under the hood use.
Ahh so with a weak alt it still will support 2500 watts for how long?
Wolverine19D
Wolverine19D
West Virginia
9515ROB
