kinetic hc600
lbss
my setup is a 12w6v2, 500/1v2, the epicenter, kinetic hc600 and kenwood HU. okay ive been doing some readin but have not found an exact anwser to my question. I was driving the other night back from work and all of a sudden my HU turned off but back on. When i checked the fuse on the power wire it was blown so i replaced it. Last night i was bumping to check it out then my interior lights started dimming some and tail lights dimmed some not as much as before i got the kinetic... my question is...is a lil dimming normal although i have a hc600
like 10% bigger than all ur amp fuses added up
if you have 1180 amps of fusing usea 200 amp fuse at the battery
thanks, also if i recharge the battery will this help stop the dimming a little more?
thanks for the attachment only thing is dat i dont have the negative frm car battery to kinetik i have negative from kinetik to ground is this good or no? checked the battery today and it is full still at 12.6 the dimming is only in the inside when the bass is hitting real hard.
Every time I have ever charged a kinetik that rested @ 12.6 v it took a charge and rested at 12.8. With a 4 amp charge it would take a good 20+ minutes from an agm intelligent autocharger.
should i get some more 4 gauge wire and instead of having the negative grounded run it to the front battery negative
Its worth a try,In my truck I had an HC600 for a a bit and I ran my ground for it back too the battery, thing is though by the time the ground made it to the distrobution block it was 0 ga back up front to the HC1400
lbss
lbss
LA, CA
AlterEgo99
NorthFramingham
    Jun 30, 2026
