Kina dissatisfied... 3 12" JL 12W6's
Used to use it all the time as a kid and never had a problem. Just gotta use the high temp stuff instead of the low temp. Use it a bit now and then now. Originally from FL and now live in Las Vegas. FL heat ain't got nothing on the desert.
Must be much higher temp than the stuff i see advertised as 'high temp hot glue' here, because i left a piece of r/c equipment that was joined w/ the high temp hot glue in my car one day and it came apart //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Temps in fla can't be much less than in the desert, especially in a car; surfaces in direct sunlight get to almost instant burn levels on a reasonably hot day.
Ouch...
I tuned for an hour while idling and tried quite a bit while driving and to no avail. THe sound is so bad in my truck that I can't even bear to listen to it... I will take some pics then post another thread so ppl can suggest to help me fix it. It's bad enough that I just leave the system off while driving //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
LoudCrownVic
1/1 of Team Team Team
LoudCrownVic
Scales Bump, IL
LoudCrownVic
