Kickpanel help
jeeper07
Rebuilding&Reconstruc ting
Well its my first time, and i cant get it all smoothed out for paint. I sanded for a bit and didnt see any reall improvement. I know i need a lot more sanding but im wondering if there are any tricks to it. Ill post pics if it helps but they are FAR from done. Basically i dont want to sand for 3 hours tomarrow. Save me
If there are high spots just use an angle grinder with a roloc disc. If the piece is pretty smooth with a few imperfections, high build primer works wonders. For small pinholes a bit of glazing putty does the trick eveytime. I'm sure all these tips are in the stickies but I hope it helps. Technique is a little hard to explain without having the piece right in front of you.
jeeper07
jeeper07
Indianapolis, IN
jeeper07
