Kickers not hitting hard at all
lilkiller
I just installed 2 10 inch kicker comps behind the seat in my truck. Theyre being powered by a kicker sx650.1 in a 2 ohm configuration. The subs are getting power as they are hitting with the music, but so little that you can barely hear it. Anyone know what the problem can be?
out of phase means that one sub has the negative and postive backwards and is moving in the opposite directions as the other sub and is canceling out.
I checked my wires and theyre not out of phase. It can't be the headunit because its stock and theres no area to change subwoofer settings. I had to use a LOC to connect it.
The wires going from the amp to the box might be correct + to + ect. but they might be wired in reverse inside the box going to one of the subs. Just try reversing the + and - going to one sub at the amp itself and see if anything changes. Or if you had a bass CD with a sweep down to 1 Hz, you could probably tell that they are moving oposite each other at below 5Hz.
lilkiller
lilkiller
Roseville, CA
bigbang
BP1Fanatic
BP1Fanatic
