Kicker ZX750.1 (mono amp) with two 2-ohm Kicker subs (10CVT102) Can I make this work?
  • 2
I95SUXS
Hi, I've been doing a lot of research on this matter but I just want to verify. I have a picture attached of the set up someone posted on here for mono amps with 2 subs. What I'm wondering is if the set up (i.e. models I have) will work.
I have the kicker ZX750.1 mono amp (Link: Amazon.com: Kicker 11ZX7501 / ZX750.1 / ZX750.1 Mono Channel 750W ZX Series Amplifier: Electronics)
and two 2-ohm kicker 10CVT102 subs (Link: Amazon.com: Kicker 10 CVT10 2-Ohm 10" CompVT Subwoofer - 10CVT102: MP3 Players & Accessories).
Will making them into a parallel series create loss of power? My amp is rated at 933 RMS (which obviously it wont use that high of an amount...but I'd like to get a good 200 or so for each sub...they are also both rated at 400 peak..so 200 should be okay..maybe even up to 300) Any info is appreciated!
383
909
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
I95SUXS
I95SUXS
Fairfax, VA
zelix
vlusardi
    Apr 27, 2024
    Apr 27, 2024
