Kicker ZX460
  • 4
Rightbrained
SOLD , thanks !
Kicker ZX460 4 channel old school power.
The amp is in great condition and includes the SWX module.
# 2-, 3-, 4-channel output
# Tri-way capable (Tri-Way crossover required)
# 30 watts RMS x 4 at 4 ohms
# 60 watts RMS x 4 at 2 ohms
# 90 watts RMS x 4 at 1 ohm
# 120 watts RMS x 2 at 4 ohms in bridged mode
# 180 watts RMS x 2 at 2 ohms in bridged mode
# stable to 1 ohm in stereo, 2 ohms in mono mode
# frequency response 10-28,000 Hz
# MOSFET power supply
# requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
# rear channel switchable high-pass crossover (100 Hz at 24 dB per octave)
# discrete output transistors
# silent turn-on/off circuitry
# removable endcaps and logo plate
# 14-9/16"W x 3-1/16"H x 10"D
$85.00 shipped (lower 48)
The only issue it has ever had is the swx module doesnt fit real tight and thats a known issue with these amps. I put a small piece of paper between it and the base and its all good.
I got the amp at a good price and I am passing the deal back on to you guys. Im not into screwing folks or my fleabay feedback wouldnt be around 600 with 100 percent !
881
Rightbrained
Rightbrained
LA.............Lower Alabama
Rightbrained
