kicker zx1000.1
motox_727
alright so two months ago some joker turned up my gain and it burned up something inside my amp.. so finally i decided to open it up and see if i can fix the problem myself... there is a large coil with a white and yellow wires coming out of it.. they are hanging there and i see the spot the need to be soldered at.. the only problem i am encountering is which wire needs to be soldered to which terminal.. i will add pics in 2 mins
my.php
the white line is the white wire obviously and the yellow line is the yellow wire..
the blue dot is one of the terminals.. the metal around the blue dot would connect that wire to the yellow wire which is right next to it... so would i want to put the yellow on that one? or do i even want yellow and yellow touching?
and then the red dot is the other terminal..
i just need to know which wire goes where if anyone knows... thanks
motox_727
motox_727
Omaha, NE
Dingleberry
