Sold Kicker ZR360
eggster
I have a pair of old school Kicker ZR360 2 channel matching amps for sale.. Amps are 7 out of 10 in appearance, both are pristine on the inside, no signs of overheating or use, look fresg out the box mint inside. OS US made amps, make for great SQ, clean, tight, detailed and reliable, these amps are indestructible. Great for mids and highs in a high power system (90x2 @ 4 ohms each 180 x 2 @ 2 ohms) or bridge them and use 1 left/1 right with 360 watts each side to crush your components.. or good for use in a smaller SQ system. Incredible detail.. Will post pics soon.. Not sure what to ask, looking for best reasonable offers.
I have the MRX midrange crossover module and I have additional chips which you can swap out. It contains a pair of 100HZ chips that can be removed, I have other chips with higher and lower values so it can be tweaked..
This amp sounds amazing, my cousin has the same one powering a pair of Fosgate RFP 1212s (old school Fosgate Punch DVCs) That setup has the nicest sounding sub section I've heard in a while.
if so, its cheaper for him to ship them @ 150 to me than you //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif i like your price point LACRX
BTW, these are not US made, Korean built but made with exceptional quality control as the amp has stood the test of time.. The rest of my amps are US made
1) Orion Extreme 900.2
2) Soundtream D200IIs
1) Hifonics Zues VII (old school from 1987) Deal pending on that one..
2) PPI A1200.2s
1) PPI A600.2
These are all working tip top, US made amps Kicker ZR360 is not..
These others are both US and foreign made, need small repairs..
1) ADS M860 (8 channel beast in mint condition, needs small repair, will have it fixed)
1) JBL GTO755.6 II 5 channel amp, sub section as well as 4 channel for highs, mint condition, 1 left channel is down.. Will have it repaired
2) JBL GTO 1201.1s Both are in protect mode, found a burnt output on each, will have them repaired..
1) PPI AX400 in very nice condition, all 4 channels work but low output, will have it repaired..
Sorry for the confusion..
eggster
eggster
Boca Raton Fla
eggster
michigan born
    May 14, 2026
michigan born
    May 14, 2026
