Kicker ZR240 2-channel amplifier -- $100 shipped
  • 4
nvturbo
Kicker ZR240
Picked this up about a month ago but decided to go with a smaller size amp. Tested and works fine. Has the typical scratches and knicks. Will come with the MDP module and name plate, NO ENDCAPS.
Power rating:
60w x 2 @ 4 ohms
120w x 2 @ 2 ohms
240w bridged mono @ 2 ohms
MOSFET power supply
MADE IN THE USA
These amps are way underrated and can push out 500 watts.
PRICE DROOOOOOOP!!! $85 //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
FREE SHIPPING within the continental U.S.
499
990
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
nvturbo
nvturbo
North Carolina
nvturbo
Brendon Jenness
    May 8, 2024
    May 8, 2024
