Kicker vs what else? Upgrading from Kicker Comp 12
blaze_01
Hello.
I am going to upgrade.
i have a series of questions and will ask here.
Info about car: Nissan Primera P11 1997 GT. Its a enclosed trunk. (sorry english)
Current Setup 2x Kicker comp 12 (150wrms 300wmax) bought with case
picture: www.vminnovations.com/sys/resource.ashx?guid=402a73368fcd48a5afc308a92cb04bf9&w=600&h=600&p=10&x=07DC124.jpg
These subs run on a ''Lanzar'' Amp.
I dont know too much about this amp, i got it with the car, and its a amp from the 90's.
Ive been told that these was premium back then and very good.
The amp is 400wrms, i think it is two or four channel.
its serial connected and i get 400wrms.
I am thinking maybe the amp is old and thats why i dont feel confy enough with my setup?
would i get much of a difference getting a modern amp?
I might consider having a new amp, because im planning getting new subs too.
my plan here, is to use the same case for the new sub(s)
The only thought i had so far was getting one Kicker L7 or doubble L3's.
Just a thought. Then i found out that people say kicker is really overpriced.
i am looking for a good sound and a sub capable of playing the bass at higher notes very well withouth loosing the ''move air'' feeling.
I dont know how to explain. But i need to really feel the sub. And the sub must be able to play well at higher freq's.
I listen to music that have very variating bass and i want good power at all ranges.
I am not a ''subwoofer'' enthusiast, so im not buying this just to show of my bass.
I have good speakers and can play loud in my car, my problem with my current setup is that if i play very loud, the sub stops and cant go higher while speakers do.
also these subs doesnt make me feel good if you know what i mean.
i need to feel those vibes.
So lets say, i already thought of getting a L3, the L7 is too expensive for me, for the price of the L3, what other sub can i get instead giving much more power for the same price and same or better quality?
any tips on build?
I have found 50% off on
''JBL MS-12SD2'' 450rms 1800wmax.
I have decided getting one of these on my lanzar opti oldskool amp.
if im not happy i will get another one and buy a 1000rms amp.
should this be considered good power?
For the money i wont go with Kicker.
There is a new company called C2 audio that has a very good price on their beefy subs, are you shipping this internationally?
if you need an inexpensive amp, you can get the audiopipe APSM 1500 around $125 and should be able to run a paid of any 600 watt subs, these C2 are beefier and have a bigger voice coil than the other subs in its category.
good luck pm me if you have any questions
Threatcon 2 with 3 inch voice coil Sub 12" very beefy 600watt $129
C2 Audio Threatcon-2
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
blaze_01
blaze_01
Norway
naughtyca
michigan born
    May 14, 2026
michigan born
    May 14, 2026
