Sold kICKER SX1250.1
Safe_Cracker
I have a nice used Kicker 1250.1 simply the best amp I have ever owned in that power range, actually I have 4 of them! Honestly Kicker might as well stop making amps now because this is the best they would ever be able to do, so many features. I used maybe 1/4 of the features this amp offers. I have had zero problems, has end caps and has normal use scratches. This includes original box, birthsheet, remote gain adjustment (bass knob), manual and everything else it has. I have owned this amp since 04 along with the others and paid a mint for it! I am asking $320 shipped to the lower 48, pics available on request... Polo.
24-bit audio resolution
44.1kHz sampling frequency
0.7 millisecond response time allows additional, non-digital amplifiers to be used in the system
Kompressor adjustable expansion / compression system
Contour Mode fattens bass output at low to moderate listening levels
Attack Mode enhances the sharp, quick attack in bass and midbass
Redline Mode controls dynamic peaks for a more even output
Digital high- and low-pass crossovers
10Hz – 60Hz variable high-pass frequency adjustable in 1Hz steps
30Hz – 200Hz variable low-pass frequency adjustable in 1Hz steps
6 – 24dB / octave variable high-pass crossover slope
6 – 48dB / octave variable low-pass crossover slope
Digital KickEQ fully parametric equalizer
20Hz – 200Hz variable frequency adjustable in 1Hz steps
0.5 – 10 variable bandwidth (Q) in 0.5 increments
Boost or cut 0 – 18dB in 1dB steps
Selectable phase
UltraMatch gain control circuit
5-stage input circuit for optimal level matching and the best signal-to-noise (S/N) ratio
1, 2, 4, 8, or 16-volt input range selection
12dB adjustment in 0.5dB steps for each input range
Memory presets
4 presets for installers or tweak-a-holics
Each preset is pre-loaded with common settings for easy setup
Customize each preset for quick access
Sick Bay diagnostics
Real-time amplifier diagnostics and troubleshooting
Keeps a running history of past trouble faults
Check current voltage and temperatures
Recall minimum and maximum voltages
Recall minimum and maximum temperatures
ISIS Vacuum Fluorescent Display.
1250 watts rms into 1ohm
PDF manual > http://www.kicker.com/06/tech-support/manuals/manuals/04SXClassDAmpMANUAL.PDF
Here ya go.. There are a couple of scratches from the end caps and a couple from things in the trunk but all is good. I really like these amps honestly best I have yet to own with the DSP functions is something awesome.
funny that you listed everything about the amp except the power ratings lol?
1250 rms, 1ohm mono hence the name 1250.1. BTW- no shipping to Canada no matter how close ur dollar is to us now //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Polo..
PS- Sorry no trades, gotta free up some room and cash! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Come on guys, this has the same great stability as a Kicker kx1200.1 but it is digital, you can even set your bass boost point no more having to settle for it to be at 40hz, you could even boost at 20hz! Also has a cooling fan unlike some of the new Kickers.... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Polo..
p.s. canada dollar is TAKING OVER haha soon enough you guys will be flocking to canadian car audio for deals! lol
NOT REALLY but whatever.
nice amp man B\//\/\P
Safe_Cracker
Safe_Cracker
Chicago, IL
Safe_Cracker
NorthFramingham
    Jun 30, 2026
