Sold kICKER SX1250.1
Safe_Cracker
I have a nice used Kicker 1250.1 simply the best amp I have ever owned in that power range, actually I have 4 of them! Honestly Kicker might as well stop making amps now because this is the best they would ever be able to do, so many features. I used maybe 1/4 of the features this amp offers. I have had zero problems, has end caps and has normal use scratches. This includes original box, birthsheet, remote gain adjustment (bass knob), manual and everything else it has. I have owned this amp since 04 along with the others and paid a mint for it! I am asking $320 shipped to the lower 48, pics available on request... Polo.
24-bit audio resolution
44.1kHz sampling frequency
0.7 millisecond response time allows additional, non-digital amplifiers to be used in the system
Kompressor adjustable expansion / compression system
Contour Mode fattens bass output at low to moderate listening levels
Attack Mode enhances the sharp, quick attack in bass and midbass
Redline Mode controls dynamic peaks for a more even output
Digital high- and low-pass crossovers
10Hz – 60Hz variable high-pass frequency adjustable in 1Hz steps
30Hz – 200Hz variable low-pass frequency adjustable in 1Hz steps
6 – 24dB / octave variable high-pass crossover slope
6 – 48dB / octave variable low-pass crossover slope
Digital KickEQ fully parametric equalizer
20Hz – 200Hz variable frequency adjustable in 1Hz steps
0.5 – 10 variable bandwidth (Q) in 0.5 increments
Boost or cut 0 – 18dB in 1dB steps
Selectable phase
UltraMatch gain control circuit
5-stage input circuit for optimal level matching and the best signal-to-noise (S/N) ratio
1, 2, 4, 8, or 16-volt input range selection
12dB adjustment in 0.5dB steps for each input range
Memory presets
4 presets for installers or tweak-a-holics
Each preset is pre-loaded with common settings for easy setup
Customize each preset for quick access
Sick Bay diagnostics
Real-time amplifier diagnostics and troubleshooting
Keeps a running history of past trouble faults
Check current voltage and temperatures
Recall minimum and maximum voltages
Recall minimum and maximum temperatures
ISIS Vacuum Fluorescent Display.
1250 watts rms into 1ohm
PDF manual > http://www.kicker.com/06/tech-support/manuals/manuals/04SXClassDAmpMANUAL.PDF
p.s. canada dollar is TAKING OVER haha soon enough you guys will be flocking to canadian car audio for deals! lolNOT REALLY but whatever.
nice amp man B\//\/\P
You know I have nothng against Canadians, use to sell/ship stuff there all the time until those stupid border hounds started to hold sh!t for a month and charge excessive amounts to get it there I had to stop! Now as far as your dollar catching up, well that is is a bit embarrasing but remember when Bush farts and lets out some of that middle eastern oil, that will be all overrrr , lmfao ... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Polo.
1 Canadian dollar = 1.001001 U.S. dollars from google as of now... Take that!!!!
These amps are amazing, I've got this one as well as the SX600.2 and the SXRC. Get the sxrc and you can control everything on the amp and get voltage and temps from the front of your car. Great for tweaking
Ohhh shiiattt, watch out Bush won't allow that for long, lmfao... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Polo.
B
U
M
P
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Safe_Cracker
Safe_Cracker
Chicago, IL
Safe_Cracker
