Kicker shattering glass againā€¦
  • 2
JakeW
CarAudio.com Regular
If this is all I need to shatter glass, lets get her going! šŸ˜‚ all that lithium and alts are unnecessary apparently
473
963
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
JakeW
JakeW
Thornton co
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
