Kicker rms rating
they can handle more.. but not much more.. only if its 100% clean and unclipped.. once that dirty signal gets in there they're toast
exactly, so long as its clean power, you should be fine. Ive pushed kickers past their rms rating, and they wouldnt even distort or anything, but it was clean power
x2, as long as the signal is clean, they should be fine. But if they start getting stinky or hot you have a problem...
Well, I sent 550rms off a fosgate to CVR's, and they were fine. If I bumped for extended periods tho, id smell voice coil. CVR rated at 400...if that answers the op's question
purposely throwing woofer across room)
hahaha....although Ive seen some DD's that if you threw across the room would put a whole in the wall and damage everything around it!! thats funny though...I chucked a Lanzar one time
well i mean they are rated at 450 rms
my cvrs were rated for 400 and I sent 550 without distortion...
i HAVE HOOKED UP MY 10" L7 WIRED TO 2 OHM TO MY kICKER ZX.1500.1 AMP AND IT WAS CRAZY, over double the rated rms, but if I tryed that with a clipping sigal it would probley go up in smoke.
LoganSF
LoganSF
Baltimore, MD
putergod
