Kicker or MMATS???
OldManTod
Grilling is my Passion!!
I am looking for opinions before tomorrow.
I have a MMATS and Kicker kx350.4 and I need to figure out which to keep and use (never mind the kx1200.1 driving the HX2's).
Both are rated about the same power and I will be driving a set of CDT comp's up front and a pair of CDT coax's in the back (soon to goto Comps in the rear doors too).
Which would you install and which would you get rid of??
I am looking for volume outta these guys if that helps.
Thanks,
T
I always lean towards the most clean power- Kicker, I know they are underated so you can expect rated power and then some before clipping-thats what matters
Kicker is the better name, happens to match , same power -you have it-perfect
How do you figure that kickers power is cleaner, and how do you figure its a better name.
id run the kicker, mmats has the worst cs ive ever dealt with...their more concerned with making washing machines //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
I misworded my statement. Not indicating that Kicker's power is cleaner- but that with my experience with their amps the power is there and then some- so while it matches his other amp,no reason to stick to the Mmats when its nothing extraordinary in comparison. In this case both amps rated the same, should look into other deciding factors other than power. The KX is current, the Mmats(if rated the same) I dont believe is. If the MMats in question was rated higher....well I'd still pick the Kicker //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif Its what I know, Its my recommendation and opinion.
You can have yours...
I've used their amps for a good decade stretch, rock solid. while the first time i saw an Mmats amp was at a booth at my local flea market.
OldManTod
OldManTod
Cle-burbs, OH
spicmonster
vegang
vegang
